I have a small problem, trying to print from R 2013 some pdf's of a long section of a building...aprox 30 m.With a scale of 1 to 20 ,,,the pdf just looks bad and unclear when you get to zoom a little bit in it.What am I doing wrong,although I use settings like highg quality pdf and so on.
I used cute and bluebeam,,,same result
if you use Print Setup >Hiden Line Views > Vector Processing , then the pdf increase its quality ...
PDF is a vector format by default and it can be zoomed at high values... Try to zoom a vector pdf and a raster one at 400% you'l see the difference...
Constantin Stroescu
