Revit Architecture
Revit Architecture
Valued Contributor
bmillerponcho
Message 1 of 2 (292 Views)
Predefine Room Names with Identity Data?
292 Views, 1 Replies
10-23-2012 10:48 AM
I do a lot of cookie cutter type buildings with pretty much the same room names and finishes for each building. Is it possible to predefine the room names with the identity data (to incl. base finish, floor finish, occupancy etc) in my template file and then just select this as I place the rooms?
I have tried creating the room with the identity data but all I can do is select the room. The predefined identity data does not translate to the new room number.
For example:
I create a room called 'Room Test 1' with a base finish, ceiling finish, floor finish and wall finish. I then go to place a room on the drawing. I can select 'Room Test 1' but all it does is add another 'Room Test 1' with a different room number and no identity data.
Thanks in advance.
Valued Contributor
bmillerponcho
Message 2 of 2 (289 Views)
Re: Predefine Room Names with Identity Data?
10-23-2012 10:56 AM in reply to: bmillerponcho
Just figured it out! On the option bar there are... wait for it... MORE OPTIONS! Well, who would have thunk it.After making my room schedule I can then place rooms. When you go to place a room, after selecting the room button go to the options bar and select your room from the list of rooms. I was so caught up in the properties bar that I forgot to look at the options bar!
