hello,
I'll try to explain my problem as clear as possible 🙂
I Use the
"realistic view" to show my clients the Sketch plans.
obviously this is shown in the floors.
I do not understand why but my floors are shown in an angle!
I've tried everything I can think of to fix this with no succes...
I've try to change the angle of the material and this does not work (it's as defoult in 0)
I've tried to change the material and the same thing happens....
I've tried to align the material in every view possible but it does not work.
I've tried materials in revit and new ones I've found in revit
I've tried to make a new material and a new floor
I've tried to duplicate a "good" floor and change the material
NOTHING WORK!!!
Another crazy thing is that other floors are ok!!! 😞
I'm attaching a pic so you understand the problem.... PLease help me!!! my clients are waiting for the plans! 😞
Can you attach your file so i can inspect it
Strip and purge your project until the problematic floor remains (check that problem still exists in stripped version) or upload it to a site like dropbox/wetransfer and post the link.
Louis
Please mention Revit version, especially when uploading Revit files.
you could upload it to your Autodesk 360 account and public share it and give us the link. Or as said above, Purge/delete all the unnecessary stuff and post it on here. We only really need the floor with material, everything else is not important so can delete it. Obviously save it first with a different name before you delete and post it 🙂
