So the power went out in my office twice yesterday while I had Revit open and today every time I open Revit it tells me no license is available. There are plenty of licenses available so what file to I need to mess with to get this working again?
Revit 2011 Web Update 1
Windows 7 64 bit
Network license
Solved by ryan.duell. Go to Solution.
Solved by GREGBIALLAS5728. Go to Solution.
What is the error code you see when you launched Revit?
My first guess is your server is also down, and when it restart, the network license manager doesn't start the license service at startup.
I found the solution via Google. I just had to delete the cascadeinfo.cas file and restart my computer.
I wanted to attach the technical solution should anyone else read this thread as well:
http://usa.autodesk.com/getdoc/id=TS13922551
