How do you make a wall that's not rectanglar (in plan view)?
See attached image.
The brown color at the end of the wall indicates the polygonal shape which should be part of the wall.
Thanks in advance.
Solved by constantin.stroescu. Go to Solution.
Use a Component - Model in Place:
Architecture >Component >Model in Place > Family Category and Parameters >Walls -OK - name it >Void Forms>Void Extrusion -make the extrusion at the desired height > Modify >Cut - select the Void and the Wall that has to be cut..>Finish Model
Your Name
