Polygon Wall Problem
3 REPLIES 3
GHASEM_ARIYANI
360 Views, 3 Replies
hi
Why when Drawing wall With Tool Polygon Surface External Wall Inside the polygon Placed.
Is there a way There are The default In the external Be.
Not pressing Space While drawing.
Because the radius is important for me.
thanks.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
3 REPLIES 3
It seems that there is indeed a problem with the wall orientation...at least I didn't find the solution...
Personally, I do not find it very frustrating because I prefer to make first a geometric sketch that allows me a more accurate approach :
  1. First , I draw a polygon : Architecture > Model Line > Inscribed (or Circumscribed ) Polygon .
  2. Then: Architecture > Wall > Pick Lines....use TAB in order to select the entire polygon and hovering the mouse control how the wall is placed  (image 1 and 2) on the polygon edges....
But , as I said, this is my personal approach....
Constantin Stroescu
BIM Manager AGD
Your Name
hi
Namely I draw One Polygon Should be Of several Tools I use.
No - I do not accept
Yes, I agree with Constantin. I would draw a polygon with lines, first, then I would draw walls following that polygon as a guide. Not a big deal.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
