hi
Why when Drawing wall With Tool Polygon Surface External Wall Inside the polygon Placed.
Is there a way There are The default In the external Be.
Not pressing Space While drawing.
Because the radius is important for me.
thanks.
It seems that there is indeed a problem with the wall orientation...at least I didn't find the solution...
Personally, I do not find it very frustrating because I prefer to make first a geometric sketch that allows me a more accurate approach :
But , as I said, this is my personal approach....
hi
Namely I draw One Polygon Should be Of several Tools I use.
No - I do not accept
Yes, I agree with Constantin. I would draw a polygon with lines, first, then I would draw walls following that polygon as a guide. Not a big deal.
