I've been trying to set up view templates that include overrides for different point cloud files. The settings don't stick when the template is applied to other views. Has anybody else run across this or have a solution?
Solved by gregamhale. Go to Solution.
What view setting are you including in the View Template that is affecting the Point Cloud?
I tested creating a new View Template (in Revit 2015 Update Release 3), set Visibility Graphics to override the RGB color of Point Clouds (and turned off all the other conditions), and when applying this template to other views the override applies as expected.
Are you able to reproduce this in a new project?
I had two projects where this was occuring and that's why I posted. I started out from scratch to do some more testing, and of course this works just fine.
Chalk this one up to user error. The feature seems to work just fine. Feel free to scrap this post. Thanks for spending the time to check it.
Thank you for letting us know that it was project specific.
If you want to dig into what caused this, the following blog post may help narrow things down:
Tools for Troubleshooting Unexpected Behavior in Revit
