I am having some issues with point cloud in Revit 2015. Everytime I import the scan cloud it doesn't fully appear. Although, Revit recongnices the file and uploaded, unfortunately is it not visible at all. See attached image and rcp file. When inserting the point cloud scan in Revit, and then once loaded, I set it to Orthographic 3D view and then zoom to fit. I am still not able to see anything.
1. Images now attached. First image shows referece file attached as center to center. Second image shows the project position by shared coordinates.
2. Point cloud was pistioned using all three options.
3. No there is no geometry in the revit filet
After following your suggenstion, we are still unable to view pointcloud at all.
I have the same issue when linking in new pointclouds into Revit 2015. When doing it in R2014 they show up. If I open the file created in 2014 in 2015 the pointcloud shows up..
Lennart
I had the same problem, thanks to this forum I could solve the mystery. Here you can see the images of what was happening with my RCS file and the comparison after going back to Revit 2014.
I found creating the RCS file through ReCap solves this issue. Seems to convert much faster also.
