I created a EWC family and made Family Types based on different heights.
One for ADA and the other for non accessible. When I place this family in
my project the elevation heights I made using parameters in the family do
not effect the elevation in the project. It seems that Plumbing Fixtures
have a instance parameter built into it that controls the Elevation height
from the bottom of the symbol. The only way I can get my family to change
heights is to do it through this instance parameter in the Properties dialog
box and not with the controls that I made. Did I do something wrong? Is
there a way around this? What's up?
I've attached the family in case someone wants to play with it. It works in
the family but not in a project. It's also wall based. Version 9.1.
Clint
