Please describe in more details the process you are following.
1) Have you installed HP Designjet 2000 printer driver on your computer even
though you don't have a physycal plotter?
2) Are you printing to file using this plotter diriver?
3) What is in your print setup dialog? (a) Vector or Raster HLR? (b) What
option do you use for colors?
4) Do you see things OK in print preview?
5) Does it work if you use default windows file name extension 'prn' as
opposed to ACAD customary 'plt'?
6) Did you try printing to file from some other application, for example
Word (that will produce an prn file) and did it work?
"JTB" wrote in message news:414358d6_1@newsprd01...
> I have problems making PLT files in Revit. I use HP Designjet 2000 (used
> well with all ACADs) and all I can see is black background. The problem is
> that I don't have a plotter now and I have to go to a friend's office.
> Please help me a little with this, it's important. What am I doing wrong?
> TIA
> Dimitris
