Have you installed the updates for Revit Architecture 2010? Update 2 did
address some issues with TIF images. While Autodesk doesn't specifically
mention addressing your issue, they might have addressed it anyway. There
are usually things fixed in updates that aren't specifically mentioned in
the documentation.
The following link takes you to my blog where I list what was Autodesk
stated was addressed in Update 2:
http://aectechtalk.wordpress.com/2009/10/01/revit-architecture-2010-sp2-released/#more-142
Doug
www.dougbowersconsulting.com
"itmanager1600" wrote in message news:6268143@discussion.autodesk.com...
Anyone printing from Revit Arch 2010 to a KIP 5000?
It appears that since we upgraded to Revit Arch 2010 from Revit Arch 2009,
images no longer pirnt out. I have sent my files over to KIP's product
engineers and they are able to reproduce the same rsults on their end.
They are saying it is a problem with the software and not their printer
drivers. I contact Autodesk support via the subscription center and their
response was:
"I am sorry but you will need to contact KIP. Autodek does not have the
specifications for their drivers and we do not control them. You are able to
do everything on other plotters and from PDF. The bad link in the equation
is the plotter."
As a work around we have been printing to PDF and sending the PDF to the KIP
which works, but these extra steps are ridiculous and the Autodesk and KIP
are just pointing the finger at one another.
Images in projects done in Revit Arch 2009 print out just fine.
Very frustrated so if anyone is able to provide any insite to this issue,
its much appreciated.
