Hello All!
Just curious - did the 2014 version turn off the watermarking for printed sheets? I was helping some students print in 2014, and none of them had the black bars that I was used to seeing in earlier versions. Checked my home educational version, and no black bars. So did we just get lucky or did these get removed from the program?
S.
Solved by loboarch. Go to Solution.
I believe as long as you open and print from the student version, and it is still licensed, it prints just fine. If you open that file in regular Revit it will add the bars.
O God those 4 huge bars drink ink. I am glad that they discontinued them in later student versions but unfortunately I still have a version (2013) that does print those bars. Ink is high nowadays. Won't be trying to print until I am up and running with an owned version.
