PLease help to turn off purple/ blue fill in walls (plan view
3 REPLIES 3
RedMan77
4507 Views, 3 Replies
So in this view (see attached) my walls are purple.  Dont know why or how to fix.  Please advise.  This is the only sheet that is doing this and I dont know how. Please help to let me know how I can correct this.  thanks.
3 REPLIES 3
AJA14
in reply to: RedMan77
Check if you have any overrides in the VG.
Check if this is a setting in your template if you have one applied.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
damo3
Could be many things so lets run through a quick the list....
Remove any view templates if applied
Element overrides. (Right click menu to remove)
VG Check model tab overrides
Check filter overrides
Check link file overrides
Check any materials applied
Check visual style is hidden lines
Hope it helps.
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
RedMan77
in reply to: damo3
Sorry for the delay.  Was on vacation.  Finally figured it out.  Someone on team applied a color to phasing (manage tab, phases ribbon).  So once I went to the graphics override tab, and remove the pattern for cut all was well.  Thanks for those who offered assistance.
