Revit Architecture
363 Kudos
Post 11 of 13
Re: Plan Region Issues
01-26-2012 07:14 AM in reply to: Alfredo_Medina
Well, I see that this discussion ended, unfinished, as soon as we suggested to post a Revit file, just a reduced version of the file, with just levels, views, and stairs, because of this reason:
"I won't be able to...(post the file)... my boss doesn't want our floor plans posted online."
For situations like this, I have created a Consulting Forum, where offices can post their projects or families, in their own private subforum. The address is in my signature if any office is interested in this different kind of assistance.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
New Member
1 Kudo
Post 12 of 13
10-08-2012 12:06 PM in reply to: kate_vanhout
I had a similar problem a few minutes ago.  Then I watched a tutorial video and figured out the issue:
The plan region will not effect the stairs unless the stairs are 100% within the region.  You need to pull the region lines a few milimeters away from the stairs (into your walls a little), and then it works.
New Member
0 Kudos
Post 13 of 13
11-24-2014 04:23 PM in reply to: for.elise
I have just had the same issue in 2014, it seems that a plan region will not affect a stair unless it encloses the bounding box of the stair.
See attached images
