How can I switch the orientation of a structural system placed on a tilted face. In other words, I have framing that snaps to the underside, and I need it flipped to the topside of the face. Thanks!
Solved by Alfredo_Medina. Go to Solution.
Select the beams and change their "z-direction offset value".
Each beam? There is no way to do this for the whole system? So I have to do this for hundreds, perhaps thousands of beams?
If you had a hundred beams or a thousand beams of the same type, you could still select them all at once and write the new setting just once.
Another solution is to create a slanted reference plane, offset inward from the face, the same depth of the beam. Then select the beam system > Edit work plane > the named reference plane. That will shift the beam system.
