Placing Structural Systems on Face
5 REPLIES 5
kyleboyd
572 Views, 5 Replies
How can I switch the orientation of a structural system placed on a tilted face.  In other words, I have framing that snaps to the underside, and I need it flipped to the topside of the face.  Thanks!
5 REPLIES 5
Alfredo_Medina
in reply to: kyleboyd
Select the beams and change their "z-direction offset value".
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
kyleboyd
in reply to: Alfredo_Medina
Each beam? There is no way to do this for the whole system? So I have to do this for hundreds, perhaps thousands of beams?
Alfredo_Medina
If you had a hundred beams or a thousand beams of the same type, you could still select them all at once and write the new setting just once.
 Another solution is to create a slanted reference plane, offset inward from the face, the same depth of the beam. Then select the beam system > Edit work plane > the named reference plane. That will shift the beam system.
kyleboyd
Ah thanks!! Great tips, especially the second as not all my beams need to be offset. But both can be made to work, thanks!
