Hello everyone,
I am trying to make a family of wall having regular voids. I made a generic model and then loaded the family in a project to built an in-place wall.
However when I place a door on the wall, the door is not placed on complete width of the wall. Same is the case with windows. Please have a look at the attached photographs.
How can I resolve this issue? Any help would be really appreciated.
Thanks!
-Neeraj
Solved by L.Maas. Go to Solution.
The problems are the voids. As you insert the door and revit sees the void he determines this as the end of the wall (See arrow in screenshot).
When you place the wall at a solid place he determines the end as you would like (see second door). So careful placement (at the spacing between voids) can give you the desired results.
Louis
Please mention Revit version, especially when uploading Revit files.
Dear Enllnt,
I was trying to figure out a solution since quite some time now. Thank you for helping me out. All the best!
