Placing Dimension Text
2 REPLIES 2
299 Views, 2 Replies
Hello
I'm looking to accurately place dimensions a set distance from my buildings (2000mm offset, 300mm offsets there after). I've set up both reference planes and model lines but when placing the dims they do not snap to these.
Can anybody help? Ive attached a screen grab
Scott
2 REPLIES 2
gustavomello
As far as i know you can't do this in Revit. But take a look at this addin, maybe it's what you're looking for.
Gustavo
damo3
Wow, I havent seen that setup since my AutoCAD days haha, funny the things you tend to forget you use to do.
So there is an offset between dimensions, its in your dimension properties, look for 'Dimension line snap distance'. As for the initial 2000mm offset you want from the building, I sometimes use detail lines and then align visually, but no more snapping with millimetre precision. depends how 'OCD' you are about it i guess. goes in the same basket as not being able to snap align to objects on sheets.
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
