Pitched toilet floor pattern problem?
3 REPLIES 3
kettuma
488 Views, 3 Replies
Hi!
I have a toilet floor, which is pitched (for a drain) and tiling (pattern) in it.
Revit shows in plan view the pattern cutted in 4 areas, guided by diagonal lines? And each area in different way.
Illustrated in attachment - looks funny to me! ;-D
How can it be changed to single flat area, where tiles are ok? Like in a flat floor.
I want to remain the pitch though, it is visible in sections.
Thank you! 🙂
Matti Kettunen, greetings from Finland!
3 REPLIES 3
alan.quinn
in reply to: kettuma
The issue I found was that one side of the floor the tiles are not parallel. Try the following, it takes a few extra minutes, but the results are correct:
http://www.screencast.com/users/AlanQuinn/folders/Jing/media/6c11340e-3367-4fb4-a327-8ef1e4245e34
Thank you,
kettuma
Ok!
Thank you very much Alan!
Great video!
Matti Kettunen 🙂
alan.quinn
No problem, glad it worked out.
