HI
Why Pick Line Walls tool,Does not act on the ellipse?
Is there a way?
Thank you for your answer
I've used this method,But Revit software Spline and ellipse drawing,Well it does not support the project.
Revit software is very weak in many works (in my opinion)
As we can see the Pick Tool for Ellipse and Spline are not yet available for Out of the Box Walls as standard Architecture:Wall or Structure: Wall.
But if you choose to make a Wall using Component (Architecture > Component > Model in Place > Family Category and Parameters >Walls , the Pick Lines works....
Maybe it will be put on a wish list for Walls both with Slanted Wall ....
Your Name
Hello
Thanks for your answer.
Yes, I know the way you explained,
,But the reason it can not Pick Line tool to draw ellipses and Spline on to do...
