Hi, I drawing up phases in a rennovation. I have two phases
and have 3 plan views showing:
My issue is with a 3 panel window (including sliding glass door) which is to be demolished and replaced by a 2 panel window (including glass door). The remaining bay is to be bricked up. What is happening is that the demolition of the 3 bay window during the new construction phase is closing up the opening as it should, however the addition of the new 2 bay window is not creating its new opening correctly (I think). The result being that new window remains bricked up. I'm not sure if this is a display issue or a family issue.
I hope this is making some sense. Attached are screen shots of the 3 plan views described above
- Mick
Existing
New Construction
Existing
Demolition
New Construction
Solved by autoMick. Go to Solution.
So you have probably already checked this - but is everything on the correct phase - the phase created for the wall is existing, the phase created for the 3 panel window is existing, then it is demo'ed in new construction, and then the new window phase created is new construction. Right?
LD
Hi Lisa, yes I've checked all is correct. I think what is happening is that there are four things happening during the new construction phase, and revit is not getting them in the right order. What should happen is:
- old window is demolished
- old opening is closed
- new window is created
- new opening created
but what I think is happening is:
I've read elsewhere that there is no need to create a separate phase just for 'demolition' but maybe this is a case where it is required?
Actually, I've just fixed it. I moved the new window to a new unaffected part of the wall, then moved it back to to the correct location - and now it works as desired. Thanks for the input.
Regards
- Mick
