Phasing for a wall opening?
8 REPLIES 8
Message 1 of 9
autoMick
10922 Views, 8 Replies
Hi, As part of a rennovation project I'm trying to draw an existing wall, which will have a section cut out of it during the new construction phase. But I'm having difficulties. What I've tried:
- Wall opening: I can't set a phase to the wall opening
- Void model: Error saying the void doesn't cut anything
- splitting the wall (horizontally and vertically). This works acceptably on a simple model (see pic), but on my house model, I can only seem to create the vertical split in the wall. What could be going on here?
Any suggestions?
- Mick
Civil3d user in Australia since 2012.
8 REPLIES 8
Message 2 of 9
rosskirby
in reply to: autoMick
You'll have to make two walls, since you can't demo part of something in Revit.  Edit the profile on one wall to make the L shape in your image, then make another "infill" wall for the remainder that you can demo.
Hope that helps.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 3 of 9
autoMick
in reply to: rosskirby
OK, I think that'll work for me. Any idea why adding the horizontal split to my wall in my house model may not have worked?
- Mick
Message 4 of 9
damo3
Hi Mick, i think you will find a generic model opening family will be best for this. You can create one from scratch cutting openings or use a door family and change it to generic. Insert the opening into the wall just as you would a door, in the new phase. It will appear demo in the demo phase.
Hope it helps.
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
Message 5 of 9
autoMick
in reply to: damo3
That's what I what I was after Damo - works perfectly. So simple yet so elusive !
- Mick
Message 6 of 9
damo3
No problem. Glad it helped.
Good way to model in lieu of editing wall profiles. Create a standard square and arch opening, covers most of my needs.
Message 7 of 9
autoMick
in reply to: damo3
Damo3.... one more question. Is there a way to make the family such that it is easy to snap/align the opening extents to geometry in the model? I can create a wall opening family no worries and have set the width and height parameters to appropriate reference lines in the family, but when I use that family in the model, I need to measure the intended width, muck about with width and position a bit to get the opening in the right place. With a normal wall opening (not a family), the sides can be dragged independently and aligned quickly to where they are needed. Can the same be done for the family version? Wow, I hope this makes sense?
- Mick
Message 8 of 9
damo3
Haha yeah makes perfect sense. So make a family that uses instance parameters and mark the reference planes as strong references. This will allow you to align edges and push pull as you desire.
Hola if you have problems.
Message 9 of 9
autoMick
in reply to: damo3
That's what I need - thanks !
- Mick
Rail Community
