Phasing and Materials
3 REPLIES 3
sandovala
1236 Views, 3 Replies
When working with phases in Revit, when you have elements in the existing phase, how can one make the model components reder according to their materials, instead of the existing material?
3 REPLIES 3
in reply to: sandovala
Set the phase filter of view that you're rendering to Show Complete and the phase to New Construction. AL > When working with phases in Revit, when you have elements in the existing phase, how can one make the model components reder according to their materials, instead of the existing material?
Remove the Material from the Material column in the "Graphic Overrides" tab of the Phasing dialog. "sandovala" wrote in message news:25464292.1097178868313.JavaMail.jive@jiveforum2.autodesk.com... > When working with phases in Revit, when you have elements in the existing phase, how can one make the model components reder according to their materials, instead of the existing material?
sandovala
Al,
Thanks for the tip it seemed to work.
