Hi
I'd like to phase a multi layer wall :
I've a type wall composed by two layers : one concrete and one insulation layer.
I'd like to create one "creation phase" for each layer.
I tried creating "elements" but it's not very conveniant to select all the insulation of my project (even if the plug in "quick select" helps).
If someone has a solution ..?
Thanks a lot !
You could try:
1. Model the "layers" as separate walls, and control phasing individually.
2. Create Parts; and see if you can assign a Phase to each individual Part of the compound wall ( not sure about this--will have to test.)
