Phases question
2 REPLIES 2
209 Views, 2 Replies
Phases question
I'm in the process of creating a new template for our office , so far we used the Architectural Template that come with Revit. And I like that has only two phases (New and Existing) . However I opened the construction template that comes with revit and I found at least 6 phase setup. And I would appreciate it if someone of experts here tells me what is the best way to handle phases? How many phases should I setup. We do a lot of renovation projects , so we always have existing and new elements.
Thanks in advance
2 REPLIES 2
Alfredo_Medina
@Anonymous wrote:
How many phases should I setup. ...
That question is really for your own office. It depends on the kind of work that your office does. That will give you an idea about the phases you need for your template.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
loboarch
You can take a look at this wikihelp article for some additional phasing explination and an example project showing the setup.
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Example_Project_to_Illustrate_Phasing
Jeff Hanson
Principal Content Experience Designer
Revit Help |
