I want to add a permutation of an asset to each one of them. (I'm duplicating 50 or so colored finishes and adding an embossing bump file to each duplicate.) I can do it using the following process but this will take days to do. Is there a faster way?
You can have the Asset Browser open at the same time you are working in the Material Browser, this might save a bit of time in switching back and forth.
The following image shows the command to open the Asset Browser from within the Material Browser.
