Permanent “Thin lines”,
6 REPLIES 6
JamaL9722060
5365 Views, 6 Replies
I’m wondering how to keep lines thin?! Why the Revit switch them again (automatically) to be thick?
Thank you
Best
Jamal
Jamal Numan
6 REPLIES 6
CoreyDaun
in reply to: JamaL9722060
There is no way to set Thin Lines to 'off' by default. The simple remedy is to just hit "TL" to toggle it as needed.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
in reply to: CoreyDaun
Many thanks for the help,
My issue here is to keep it permanently thin! Is there a way?
Jamal Numan
CoreyDaun
Turn off Thin Lines and then never close Revit ever again.
JamaL9722060
This is precisely my question, why the thin lines comes back automatically if you close the Revit and then start it again?
Jamal Numan
loboarch
"Thin Lines" is really just a visibility mode you toggle on and off to check the way elements are connected, etc... in the model.  It is really a kind of diagnostic mode.  If you want thin lines permanently displayed in a view you can use the "linework" tool to permanently assign a specific linestyle to an element edge in the view.  This is a view specific tool and will not reset between sessions.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
JamaL9722060
in reply to: loboarch
many thanks for the contribution
best
Jamal
Jamal Numan
