pen thickness
3 REPLIES 3
K.M. ASHRAF
256 Views, 3 Replies
pen thickness
I have a wall with 25mm thick external stone cladding with 50mm wide gap between wall and cladding. Please help me how to change the pen thickness in REVIT only for the stone cladding.
3 REPLIES 3
in reply to: K.M. ASHRAF
Are you doing this as a detail in a detail or drafting view using line work?
Have you looked for existing detail components for cladding and structural
components?
wrote in message news:5226238@discussion.autodesk.com...
K.M. ASHRAF
It is basic generic wall structure with cladding. Under wall parameter/construction/structure/function i added 50mm thermal/air layer & 25mm thick finish1 layer with stone cladding material finish. Since 25mm thick finish under same wall family, it will print with same pen thickness as wall. I want thin line thickness only for the finish.
Wotdat
-------------- L I N E W O R K ---------------------
