PDF Import?
11 REPLIES 11
Message 1 of 12
655 Views, 11 Replies
PDF Import?
Can I import a PDF into Revit to use as an underlay?
If not, can I import it into ACAD and then somehow (not much of an CAD
jockey) make it into a DWG to send to Revit?
11 REPLIES 11
Message 2 of 12
Did I mention my desperation for help? 🙂
I just landed a contract to produce some kind of rendered output by Tuesday
AM of a development. All I have access to this weekend is a few PDFs of ACAD
plans and elevations.
How can I use these?
"david" wrote in message
news:5188292@discussion.autodesk.com...
Message 3 of 12
Can I print them, then scan them to some usable format to import into Revit?
news:5188269@discussion.autodesk.com...
Message 4 of 12
Neither Rebit or ACAD up to 2004 that I know for sure, won't import PDF's. I
don't know about later ACAD versions. I would save the PDF as a JPG file.
That I know you can import into both revit and ACAD.
news:5188293@discussion.autodesk.com...
Message 5 of 12
I'm not sure you will have much luck getting a scalable result, but you
could try exporting the pdf as a jpg from Acrobat. You could get that to
scale in AutoCAD but I don't think the jpg file will show up when you
import the dwg into Revit. You really aren't ever going to get anything
you can properly trace in Revit from a pdf, so it might be better to
just jump in and start building it in Revit from scratch. Hopefully
there are dimensions in the pdf's.
Message 6 of 12
Best I could do was to print the PDF
Scan the printed PDF as a TIF
Open the TIF in photoshop
Save the TIF as a JPEG
Import and check scale
Do the calculation to adjust scale
Adjust print settings
Reprint, rescan, reTIF > JPEG
Reimport
"J F" wrote in message
news:5188304@discussion.autodesk.com...
> Revit?
> Tuesday
> ACAD
Message 7 of 12
Why didn't you just open the PDF in Photoshop, adjust the scale if
necesarry, and save to jpg.?
news:5188356@discussion.autodesk.com...
Reimport
> Revit?
> Tuesday
> ACAD
Message 8 of 12
John,
You know...I'm new to almost all of this software.
That sounds like it would work...
basically right now I've got the image imported and if I adjust to 1/16"
scale it's pretty damn close.
So I'll use it like that for the underlay.
I have a question though....
I imported to level one, but i can't see the image in my other levels.
I've tried all the standard VP settings...underlay-level 1 for example...but
still can't see the jpeg in other levels
Any thoughts???
"John B" wrote in message
news:5188328@discussion.autodesk.com...
Reimport
> Revit?
> Tuesday
> ACAD
Message 9 of 12
You will have to copy /paste it to all levels
Message 10 of 12
boydjohnson
Hey David,
I feel for your frustration. A couple things that I have used when working with PDFs. If you have Adobe Illustrator. It can import and export DWG's - usually pretty well.
Second option is to do a google search for "pdf to dwg"
There are several downloadable programs out there that make the conversion - if anything to a dxf. Usually they are free for about 15 days or so.
This is one I have used before.
http://www.autodwg.com/pdf-to-dwg-converter/?gclid=CNLdh-SanYUCFS9uFQodtiuLng
Good luck
Boyd jl.
Message 11 of 12
you could print the .pdf to .dwf and underlay that
if you have acrobat pro you can export the .tif
afterall all a .pdf is is an embeded .tif
Then convert the .tif to a .jpg since revit does not know
what to do with .tif's
the .dwf printer is free from autodesk
Dave
Message 12 of 12
thanks everyone
I didn't have anything but an el-cheapo photo program and a free pdf
utility...so options were limited
What I did was print the pdfs
scan as tifs
opened in photo program
saved as jpgs
imported to Revit
matched scale till dims were close
imported to all levels
It worked.
"David Allen" wrote in message
news:5189432@discussion.autodesk.com...
Dave
