PDF floorplan, import as revit underlay?
23 REPLIES 23
Message 1 of 24
75486 Views, 23 Replies
Can I import a florrplan in PDF format to begin a drawing?
23 REPLIES 23
Message 21 of 24
lineho
A quick way to convert is to take a screen capture (Snipe Tool for windows) and (command shift 4 on Mac) the PDF Image (save as JPEG), then import the JPEG into REVIT but do not explode.  I usually pin it just to keep it from shifting, then, scale the jpeg image with a wall or model lines at the drawing scale.  I turn on the imported layer (VG check or uncheck the imported file) when I need it, and when I don't.  I find that this old fashioned scaling way is the fastest, and when scaling, you can zoom in as much as possible to the reference points to increase accuracy.
Good luck. 🙂
EHo
Message 22 of 24
dzdmahfoud
Message 23 of 24
nakulgote
A Dyson sphere could be smaller than the Solar system of that star, right?
Message 24 of 24
ARCH-SADEQ
Same question 😞
