Is there a way to pass a yes/no parameter from a family to the tag that's tagging it in a way that will effect the visibility of an object in the tag.
Basically I have a custom family (these a wall mounted signs, speciality equipment). Some of of them require power some don't, this is set through a yes/no parameter in the family. When it comes time to tag them, I want the tag to intelligently toggle the visibility of an object in the tag based on power parameter in the family it's tagging.
The desired effect toggles the visibility of some graphics lines. The intent is not to report the parameter to a label in the tag.
Any ideas would be much much appreciated.
Cheers!
