Parts of the Roof will not join to wall / wall selection
1 REPLY 1
RJK42
985 Views, 1 Reply
I am drawing up my house in Revit to get use to the software. I created my house, and now my garage.  I selected to create a roof by footprint but when I tried to join the roof to the adjacent wall, the overhang does not follow.  I then selected the overhang to join to the adjacent wall but an error pops up: "Part of the roof to be joined misses the target face."
I attached a PDF of the roof.
Also, you will notice a line that separates the two walls I joined together.  I may separate them but how do I avoid this if I want to make one solid wall??
As for the wall selection, I have vinyl siding and would like to use properties that relate when selecting my exterior walls.  I do not see anything regarding that besides wood siding.  I thought that should be in my properties when I downloaded and purchased the software.
A jpg is attaced regarding the wall selection.
Thanks in advance!!
1 REPLY 1
alan.quinn
in reply to: RJK42
See the attached image about your roof and you will have to edit the wall type to create the wall you want. See this link for more details:
Modifying Walls
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0...
Thanks for posting.
