How do I create a parking slab with differerent finish elevation at each corner of the slab?
Please see attached PDF file.
Solved by constantin.stroescu. Go to Solution.
Select the Floor Slab > Modify/Floors >Shape Editing >Modify Sub - use Add Point and Split Line if necessary > select green points and change their heights at the desired value.
You can also use Edit Assembly ( Floor Type Edit) in order to control the layers that have a variable thicknes..
Your Name
Cool. It works.
So this only works for the regular floor slab, but not the structural foundation slab, correct?
Also, I try to do a in-place modeling of the step footing. I have the profile drawn in CAD.
How can I import the CAD file into Revit in the elevation view to do the in-place modeling?
Your Name
