Parapet Wall Capping
2 REPLIES 2
ennujozlagam
1120 Views, 2 Replies
Hi, I created a Parapet Profile Capping and loaded into my projects and edit my wall type to load as sweep into my parapet wall but i didnt show up in my elevations. What could be my mistakes or not doing it properly. Any suggestion. Please find attached.
2 REPLIES 2
L.Maas
in reply to: ennujozlagam
I think the issue is that you created the parapet sweep at 6096 from the base of the wall. Judging from your screenshots I expect you will find your parapet sweep much higher up in the view. In this case you might consider to place the sweep from the top.
Louis
Please mention Revit version, especially when uploading Revit files.
ennujozlagam
in reply to: L.Maas
Hi Enlint, sorry for late reply. im too busy. thanks for your help.
