I have an exterior wall with plaster and lathe on the exterior, and gyp board on the inside. When I edit the wall structure, and modify the layers so that I can take the interior wall finish only up to the sheathing line, the wall does not join at the corners properly. It leaves a gap for the interior fininsh at a corner above the sheathing line when looking in 3d. Any suggestions? What are you all doing with parpet walls and the interior finishes above the roof line?
Solved by alan.quinn. Go to Solution.
I have two suggestions. 1. Create a second wall type for above the parapet or 2. Use masking regions to hide the what you dont want to see above the parapet.
Thanks for posting.
