To clarify, one floor slopes 3" over 100' and splitting works, the one that
doesn't slopes 7' over 200'.
"Jay" wrote in message
news:5417252@discussion.autodesk.com...
I'll give that a try.
On a related note, the same thing is happening on a sloping floor. In this
case, however, the split face lines don't appear in plan (only in 3d) and
the paint bucket doesn't recognize different the split face.
"mjohnson" wrote in message
news:5417243@discussion.autodesk.com...
No, check the help files for vertically coumpound wall. Basically you can
split the layer at whatever height you want and assign a new material above,
like a brick wainscoat at the base. Do the same thing for different stucco
finishes or brick accents, etc.
-MJ
news:5416941@discussion.autodesk.com...
By compund wall do you mean stacked?
news:5416904@discussion.autodesk.com...
Using the vertically compound wall, split the stucco at each reveal and
start a new material with the new color. Or create one wall type for each
color with the reveal at the base, and stack them to make changing the order
easier (if the order varies, for ex.).
-MJ
news:5415877@discussion.autodesk.com...
I have a stucco wall with a whole bunch of reveals in it. The surfaces
between the reveals I want to be painted different colors. The paint bucket
doesn't recognize these as separate surfaces, and it won't allow me to draw
split face lines on top of the reveal edges. Any ideas on how to accomplish
this?
-Thanks
