Painting a portion of a face of a beam or column
7 REPLIES 7
Message 1 of 8
virajvoditel
4562 Views, 7 Replies
Is there any way to paint a portion of a face of a beam or column? By this, I mean something like what is possible using the split face command on walls.
I know this is odd, but for eg. if there is a very wide column common to two different rooms, half of the transverse edges may be required in two different materials.
7 REPLIES 7
Message 2 of 8
L.Maas
in reply to: virajvoditel
It is possible for Architectural columns, but not for structural columns.
So you can use an architectural column or otherwise "encase" the structural column in a architectural column.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
virajvoditel
in reply to: L.Maas
What about beams? That's a larger concern..
Message 4 of 8
L.Maas
For beams it is the same as structural column. Painting is not possible. Therefore you would have to look at different options.
You could modify the beam family and add a layer to the beam family. This layer you can control with parameters.
You could create a new family that you would lay over the beam.
Louis
Message 5 of 8
MRefaat00
in reply to: L.Maas
can you be more specific with details please!
Message 6 of 8
aamata
in reply to: L.Maas
For architectural columns, what's the steps to be able to paint the face of columns?
Message 7 of 8
in reply to: aamata
Hello @aamata
Just command Split Face (SF)>Select Face of your ARCH column or Beam)>Create a Layout/design etc. you wanted to have a different paints>Paint with your Desire materials
Message 8 of 8
aamata
@AnonymousThank you for the swift response. Works like a charm.
