Show only
Search instead for
So when you use the align command and align the faces of the walls to each other - they still overlap? Neither moves when you align them?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers! You can't think AutoCAD and run Revit. Email: LisaDragoEE@gmail.com
