Delete the opening. Use voids to cut the wall. You can use one or the other,
but not bot.
wrote in message news:5627755@discussion.autodesk.com...
Ladies and Gentlemen,
I am trying to create a window - that part is easy enough - however, I would
like some info on the "OPENING" part of it.
I can create the opening no problem - however it punches all the way through
the wall straight back from the opening lines i draw, this does not really
help me, as i have a brick exterior, then brick mould (so the wall actually
continues farther inward than where the opening has cut, then my window
finish does some weird stuff inside too.
What i would like to do is create an opening for the brick, then another one
for the actual wall itself, or at least create some sort of profile for the
opening in the plan view so i do not have to model pieces of my wall in with
my window.
B
