Opening's tag not fit to my needs
4 REPLIES 4
z.galic
550 Views, 4 Replies
I would like to make window's tag as shown in attached picture. But when I did it in Revit, depending of windows direction, tag behaves strange (orientation is wrong, circle with the position number is not connected with the window, ...).
Does anybody know solution?
Zvezdana
4 REPLIES 4
Alfredo_Medina
in reply to: z.galic
Perhaps you should post the family that you have done so far, not just the image.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
z.galic
Here you are...
Alfredo_Medina
This kind of family needs 2 types, Type A and Type B. If you put the tag on the project, and the tag looks wrong in regards to the window, then you change the tag from Type A to Type B or vice versa. Use the tag without a leader. There should be a set of labels and line on both sides (up and down) in the family.
z.galic
in reply to: Alfredo_Medina
Thank you very much!
