opening by floor (is there a way to see an X in the square) see pic
3 REPLIES 3
syria89
235 Views, 3 Replies
need help
3 REPLIES 3
in reply to: syria89
You can use detail lines to place the "x" into the opening. Constrain the
detail lines to the opening if you anticipate a design change in that area.
Jeff Hanson
AEC - Technical Publications
Manchester, NH
wrote in message news:5680671@discussion.autodesk.com...
need help
syria89
but it already existe, foe example if you load a windows but an opening and you select a wall then we will be able to see the X
is there a way to do the same thing but for a floor
Scott_Womack
If you use the Opening/Shaft Opening, you can, while in the sketch mode, create Symbolic lines that will appear in the plan view.
Rail Community
