Two things u need to make sure for openings! I really dont like the way this feature works for openings in walls. But note these things down.
Firstly, whats the height of the wall Is it only from Level 1 to Level 2(Example) or is it from Level 1 to Level 7(Example). Secondly wat r the Properties of the Opening? Top and Base Constraints and the unconnected height.
I've found it easier to make a wall first, from Level 1 to Level 2, and then cut an opening in the plan. And then if required change the wall to go upto Level 7, and then copy the opening to multiple levels. This way, since the opening was made when the wall was only till Level 2, the property of the opening is always between two consecutive levels when copying to other upper levels.
However, if the Opening is made while the wall was from Level 1 to Level 7, and then tried to copy the same opening to multiple levels, it starts giving the error u mentioned.
So work on it abit, and you'll find a suitable way for yourself.
