I have a file with worksharing enabled, and if I copy/paste the full path and filename into the "File name" text box, the worksharing options at the bottom of the dialog are not enabled. However, if I navigate to the file using the Open Dialog browser the worksharing options are enabled. Is there anyway to refresh the browser after I paste the path/filename so that I can specify the worksets to open? I've tried F5, but no luck.
Thanks.
Ian
