OOTB Pen Settings
2 REPLIES 2
369 Views, 2 Replies
OOTB Pen Settings
Hi Everyone,
I'm looking to start using Revit on a small project. I'd like to use as much OOTB as possible, but had a question regarding the way Revit exports to AutoCAD. Our company has a ton of custom pen tables and layers. Has anyone decided to use all of Revit's export to DWG features OOTB, and how did it work out for you?
Jim
2 REPLIES 2
yes. works great for building geometry! We export for consultant
backgrounds, internal coordination with ADT/CAD processes, and 3d models to
be linked to MAX.
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
wrote in message news:5547679@discussion.autodesk.com...
Hi Everyone,
work out for you?
Jim
Depends on what you are going to do...
Pass the DWG to a consultant? They won't use your pen settings anyway, so
the OOTB works fine for backgrounds.
Incorporate with your existing DWG's? Then you probably want to customize as
I've found the culture shock of changing pen settings too much fro most
firms. (...of course at this point you should be plotting bylayer using STB
in acad anyway.)
Hi Everyone,
work out for you?
Jim
