offset grid
1 REPLY 1
glkirk
3968 Views, 1 Reply
offset grid
I am using 2013 version. (don't find a "lock" under toolbar.
I am a student with only AutocadLT experience.  I can not find how to offset a grid line. Please, can someone help?
1 REPLY 1
LisaDrago
in reply to: glkirk
Hello - I am not sure what you mean by "(don't find a "lock" under toolbar."
As for offsetting a grid line - you have to start the grid line command and use the offset in the options bar (below the ribbon). You cannot use the offset tool on the modify tab.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
