Hi
How you can have without a shadow (Non - Shadow)of Revit can render
Render consists in presenting an object in light and shadows. Figure youself a white cylinder . If, no shadows it will be only a white flat rectangle - no 3d object....No shadows = No rendering.
But you can use the so called non realistic representations ...Visual Styles>Consistent Colors is the best non shadow example, like in cartoons...
You could try rendering a time of day when the sun is not out (3am) and then whenthe render is complete change the exposure settings to turn up the ambient light levels. This would give you a "render" without shadow.
Thank you for your response.
I look up and I needed a plan.
Although your picture, under the shadow of the building and inside the building is still there.
I want to render without shadows produced.
Thanks for the answer
You are absolutely right.
But I think wind is a good software quality and precision and also close to the real world should also be flexible.
Technically there is not any shadow in the image. There is a lower ambient light level there so it appears darker, but there is no "shadow". If you are looking for a view where light is applied equally to all surfaces you need to use the "consistant colors" visual style. Of course this will not show material quality it will only show the selected shaded color.
Any time you "render" there is going to be lighter and darker areas of the image even if there are no "shadows"
<<Any time you "render" there is going to be lighter and darker areas of the image even if there are no "shadows" >>
In fact there are two types of shadows:
