I'm a student user, and fairly new to Revit. I just installed Revit 2010 (Was using 2011 before) and i open a new project, and there are no wall types. (Usually when I click on change element type, it shows a lot of different types of walls, now there's only three- stacked wall 1, wall 1 and curtain wall 1) It might seem like a dumb question to ask, but where can I find the walls? Is it a family that i should load? Or did something go wrong when I installed Revit?
Please Help!
Hi. When you start revit, the template you start with will have types already inside. It seems you started from a blank template and so you have the system families but no types. Therefore, either open a new project from an existing template, or simply click on edit type, and create as many new types as you need.
Note: Notes are system families, and therefore cannot be created or deleted. All you can do is create new types by clicking on edit type, duplicate, new name, edit structure, change the layers of the wall, and then it becomes part of the project.
Regards.
A good template is indead the best choice...
If you have already begun a file and you realize that you need some more walls you can make a transfer from another file:
When you have only one type of wall you can use also Copy/Paste function
Constantin Stroescu
