Revit Architecture
Revit Architecture
bodi110390
Message 21 of 34 (3,153 Views)
Re: no template on my revit architecture 2012
01-05-2012 08:39 AM in reply to: bodi110390
Ok, seems like i have to spend a lot of time on this, i'll try your version , hope it works.
Thank you for your reply.
moegerbyte
Message 22 of 34 (3,141 Views)
01-06-2012 05:08 AM in reply to: bodi110390
No problem, I really hope it works for your system. In any case let me know, please.
New Member
gizem_eroz
Message 23 of 34 (3,116 Views)
01-10-2012 08:54 AM in reply to: lockmote
hi im dealing with the same trouble, i serached what you refere but i only have family templates and recent in the file. Im confused and dont know what to do :s
moegerbyte
Message 24 of 34 (3,054 Views)
01-16-2012 08:37 AM in reply to: gizem_eroz
Did you try my approach, or were you referring to the first page posts?
I have no feedback yet on how my "method" worked on other people's PCs.
New Member
timothymfullerton
Message 25 of 34 (2,898 Views)
02-02-2012 05:37 PM in reply to: moegerbyte
Hello ,ive spen 12+ hours trying to figure out what is being down loaded to where I can find it. When I turn on my new laptop it has me downloadin, asking over and over for codes,passwords ,I cantjust push a button that says ,hello fullerton college student. what would like to learn after downloading for 15 hours please help
New Member
timothymfullerton
Message 26 of 34 (2,894 Views)
02-02-2012 05:58 PM in reply to: moegerbyte
Spoke with my instructor about what has happened to me .I wanted just basic auot cad 2010. I am trying to complete my cad lanscape contracting class and we at fc use 2010 for my class. Many students have given up because files and teachers have no time and different paths to get,save files ive spent hours on;gone .With limited lab time to practice
New Member
sujayk.124
Message 27 of 34 (2,660 Views)
03-01-2012 03:57 AM in reply to: bodi110390
guys i got it resolved however...wt i did is..
i opened a default templet of 2011 and cosed it with out saving.
next i again started revit and choose d default templet dt ll be present in recent files folder in d femily templets folder in rac2012...
it shown its been upgrading...then its working normally now with out any problem...
New Member
surricata
Message 28 of 34 (2,262 Views)
04-28-2012 05:53 AM in reply to: lockmote
Hi. Now,I had some problems with my template files for RAC 2013. I had them installed, but i couldn't find them or use them. Maybe some of you had this problem, if so, this is what you have to do (and it's quite simple):
Go to c - program files- autodesk- metric/ imperial - templates and check to see your files
open revit - application menu- - options - file locations and specify the path to get to the template files. The default path is wrong.
From now, when you start a new project, you'll get to choose the template. That's it. I hope I helped someone. Have a good day.
Member
albino
Message 29 of 34 (1,978 Views)
07-13-2012 05:03 AM in reply to: surricata
Had the same problem before and fixed it by creating path to my own template file.
You can check the detailes  here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27922
New Member
lesliedlugtu
Message 30 of 34 (1,822 Views)
08-21-2012 01:11 PM in reply to: bodi110390
yup, it works. Just went to add/remove programs then uninstall then install additional components.
thanks for the post. It hurts my brain to figure that out!
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
