Revit Architecture
Distinguished Contributor
dexx
Message 1 of 2 (427 Views)
No Resource dll
427 Views, 1 Replies
12-18-2003 04:36 AM
I get this message when i try to install Revit 6 on a windows 2000 operating system
Any Ideias?
Thanks in advance
Sérgio
New Member
dandy
Message 2 of 2 (427 Views)
Re: No Resource dll
12-18-2003 06:06 AM in reply to: dexx
Had the same over here and found a solution. You probably have a non US Windows version and the installer is missing the appropriate RevitInstallXXX.dll where the XXX stands for the language code.
Workaround:
1. download webinstaller but don't run it
2. instead unzip the exe and put in a directory.
3. copy your RevitInstallXXX.dll file from where you have installed 5.1 to this directory
4. start installation with RevitInstall.exe
It did work for me ;-)
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
